12/18/11
Made the bracket to go over the tank that holds the amp and will now hold the optima battery as well-I moved it from the drivers side of the trunk. Why i put it there to begin with, i have no idea.
Hey look, I made a semi-decent weld.
Wiring is now all wrapped up and neatly tucked away.
Lokar E-brake handle installed in trans tunnel
Fuse panel moved from trunk to rear seat area, which will be covered with the 66 Shelby seat delete.
Seat delete trimmed and temporarily installed. Excuse the fiberglass dust. Quarter panels were also trimmed to fit around roll bar.
Why the wiring takes so long-each fitting is crimped, then soldered, and then I put heat shrink over the wire and connector.
Had to remove the fuel tank due to some issues, so i went ahead and put herculiner on the trunk floor and then rolled the quarter panels and outer wheel housings with satin black paint.
