Thinking about doing it but does any one know of a good video or tutorial on how to do it?
also what do you think of it?
I didn't do this to my GT but on my v6 I remember doing it. Buy two small hose clamps at the hardware store, and one nylon spacer (1"). Grab a hack saw and cut into the side of the spacer so that you can fit it over the throttle cable. It's easier to do this with the spacer held in place by table vice or vice-grips. Once done, fit over the hose clamps and clamp each side down tightly with a screw driver. A nut-driver will give you a bit more torque if you have one, which I prefer when tightening hose clamps.
Definitely doing it tomorrow after reading that
just buy some hose clamps they are like 20 centsHow would high strength zip ties hold up?
i don't trust them for this job...that's why i always use two small clamps...hell this mod runs usually $2 at any hardware store for parts....it's the first thing i've done on my last 3 stangsHow would high strength zip ties hold up?
Seems like it would be a noticeable difference, is it to you?i don't trust them for this job...that's why i always use two small clamps...hell this mod runs usually $2 at any hardware store for parts....it's the first thing i've done on my last 3 stangs
Just did this mod about 20 minutes ago, and its DEFINITLY worth it. It feels so much better when you drive and you barely have to tap the gas nowSeems like it would be a noticeable difference, is it to you?
