421 - 440 of 749 Posts
It is fairly bolt on and go. To mount it I had to use a combination of studs and bolts and then for the middle one it needs a hex head due to low clearance. There is a small clearance issue with the fuel pressure regulator, I had mine modified to fix that. I also got a better idler pulley since the KB piece is plasticrap, cant remember the part number but it is a timing belt tensioner for a Lebaron or something like that. I also swapped the KB adapter elbow out for the trickflow one, there is a very noticeable increase in size between the two. You will want to get bigger injectors and something to tune with as well.
lmao just look at the diameter of it and buy a new line :facepalm:
Im fighting the good everloving battle with that line right now man :naughty: I vow to kick its SOB ass, lol you know how it goes with the 5ohhhhs :bash: its a never ending battle of witts :swordfight:
Not sure about your cam, try it out and see. The 24lb would be on the small side, even with a FMU. For the cost of buying an FMU that is most of the cost to get a set of 42s, so may as well just go the correct route right away. Forgot to mention that the coil needs relocated.
Just treat it like you would treat your wife, make her happy lol, otherwise it will be a bitch to you all the time. I used to yell at my car all the time :swordfight: and then it finally died and never ran :facepalm: THEN I started my H/C/I build :naughty:
My cam is custom and is between a stage 1 and stage 2.
I'd just buy some used injectors, new is way too much imo...Where did you put yours? What you set your fuel pressure at?
And I have a custom chip programmed from a tuning shop, I could always bring it back to them on the dyno and have another custom tune.
I went to bleed the brakes, but the new passenger side caliper, hangs up a little, it doesnt fully release unless i push a pull on the caliper a little. Im not sure if it needs to be broken in, or if its just ****ed up. Theres a warranty, so ill try replacing it first
Used 42's would be just fine, I picked mine up off Ebay. As for the pressure regulator, the SC inlet had a small section cut out and re welded for increased clearance. My fuel pressure is set to stock, no need for anything out of the ordinary. I also have a Quarterhorse for tuning with Tuner Pro R/T. The stock maf sucks with SC apps, I run a PMAS 92mm and it was a fairly large difference in how the car ran.
:eek:hsnap Thats what I'm talking bout, seen a great write up on this blower in 5.0 a month or so ago, I like the diff from the typical centri, looks great man:drink
Thanks for the compliment. Most centri guys talk **** about their cars being faster at the track. But for a mostly street car you cannot beat having full boost by 1200 rpm, it is a freakin monster and so much fun to drive.
Would the mods in my sig work with the kenne bell? besides for the upper intake of course and 24lb injectors.
You should be ok. The 3.73s may be a bit low, I am still sporting 3.08s with serious traction problems. See how that 75mm maf works, you may want to upgrade it down the road.
I just like the fact that its way different and Kenne Bell is BA, theres tons of vortech, and Paxton powers 5.0s out there, if I was going SC I'd get the KB Great choice! Just so happens I'm going Turbo:naughty:lol
I actually still have 3.27s, haven't installed 3.73s yet.
I need to save up a little bit for a s/c, hopefully that kit is still available :D
What you doing with the 3.27s I have a turbo build on deck
