I have a 2002 with 109k when brakes are applied in the front you hear a noise kinda like stepping on a bottle, its very faint and I doubt ill be able to get it in a video, but does anyone have same problem or know things it could be?
I'd take it apart if it was me, pull the calipers off (12mm head),check the pins for free movement, if they're moving good, get a small screwdriver and pull back the piston boots, look inside for any rust. Using a c-clamp or similar, try to depress the pistons, they should move freely.So would you recommend upgrading to mach or cobra calipers, wouldn't hurt to change rotors out anyways
I all ready have cobra rear rotors because of my rear end swap
