Im about to buy rims and tires and really wanna know if i should go with 18s or 20s. What are the side effects of going with 20s. Also keep in mind i will be lowering my car.
Doink.20's will usually cost more, tires as well, depending on the brand. More rotational mass to move since its a bigger wheel so remember that weight factor. 18's are less rotational mass to move. Also fatter tires so ride quality will most likely be better, more cushion.
Its all personal preference. Its your car remember that.
Boink.Doink.
Steering wheel shake is not an issue as good tire people can balance 20s properly you don't run into balancing issues till you hit 24in and up.20s cost more. More surface area to clean. More strain on your brakes. Harsher ride. Less tire profile to protect wheels on potholes/speed bumps. Usually more issues with balance (highway steering wheel shake). Poorer handling. More expensive tires.
Traded a set of raceline 20s a couple months ago for stock painted aluminum 18s because of how much slower/shittier the car drove. Unless you've got a good "body kit" 20s look "overdone".
Save yourself the headache and stick with 18s or 19s.
Sent from my Autoguide iPhone app
I hate buying tires anyways....you always wan to get the best bang for your buck and everyone claims for the best tire !You are going to ****ing HATE buying tires!
