61 - 80 of 226 Posts
Discussion starter · #68 ·
ok so back to the topic haha. if i would take the car to someone to check it out it would be him. he gets the cars from his dads dealership and make them run perfect then sells them off. he says i should turbo that thing. because he knows the six will blow up after about a month. should i trade?
Discussion starter · #70 ·
so should i do it i mean i will have to start from the begining of mods like springs clutch upgrades lights you know stuff like that. and i know in the long run i will get more hp.
Discussion starter · #72 ·
i have this on the car now
intake h pipe adapter mac cat back exhaust steeda clutch quadrant new clutch cable and fire wall adjuster short throw shifter projector head lights saleen front bumper and rims
SSStang said:
My'StangOpens said:
the terminator is a 4.6 DOHC w/ a blower right?
how much power they putting down?
A little more than an LS-Juan with a blower on top :(
what.....a stock termi puts down like 390rwhp.....(they were underratrd from the factory)
and LS1 with a blower is gonna be putting down 425+.....and thats lowballing it.....
Discussion starter · #76 ·
i think its bone stock i dont know he was busy and it just kinda came up in conversation certain things were said like striaght trade but him and i are gonna talk about it more after labor day.
and it's still not as fast as a GT...
Keep the rims if u can.......if u don't still have ur stock see if he'll trade
you through a turbo on either of them and bump it up past 6 you put the motor in danger... the essex is stronger then the 5.0 i would trust it more...
a car has to be built to handle boost either way you look at it engine size doesn't matter
yup
however, it takes more boost to put the same power in a V6
6lbs in a 5.0 is more power than 6lbs in a 3.8
