101 - 120 of 185 Posts
yes it will ... but think. What if you cant get this to work and you spend all this time ****ing with it and then spent all that extra money on mods for something you cant make work ...
Im sure it will work. But if you run into problems that u need extra money to fix, you'll have it if you hold off on modding first.
Not as easy
Not as cheap
But you will be sure its all gonna work right
Discussion starter · #102 ·
Dammit mike...i guess ill just paint it and put the **** in the car unfinished... damn... You make a good point but james knows itll work... was he 5 speed? And the work will be done instead of all this thumb twiddling I guess.
Discussion starter · #114 ·
Its literally no more than 2" taller than stock and look at it lol..raw as hell lol..+++ bbk valve covers are no longer for sale due to the fact theyll be on me SC motor..
Discussion starter · #117 · (Edited)
Okay so an update is looooong overdue sorry.. Ive been busy to the teeth getting started with my apprenticeship to union ironwork... I dont have my phone cord with me so ill have to add my pictures later.. i have more to take anyway...
I acquired a high lift cam from a friend and fellow MM member.. another fellow friend and member has yet to recieve but has agreed to port and polish my SC heads for me.. yet another member has actually given me a set of long tube headers by pacesetter. Ive also rounded up a custom made alum top hat for my blower that ive already shown you guys on my blower. I painted the SC block, '00 timing cover, and SC oil pump/cooler in VHT high temp Chevy Orange. Ive also covered the lower intake, blower, fuel rail, water pump, oil pan, acc brackets, and all pulleys and tensioners in Gloss Black VHT as well. My brother in law and myself have taken the oil pan and lower intake and airbrushed a "flame" onto them using the same VHT in Gloss Yellow and more Chevy Orange...just sprayed the high temp paint into paint caps and poured it into the gravity feed of the airbrush... Ive learned that my dual intercooler setup is stupid and will be using a 30"x11"x3" FMIC that I have yet to purchase but is as good as mine as its my buddies old one..Ive also learned that at this point I'm going to need 60# injectors which is twice the size of what i have and i didnt expect to see that cost arising but whats new..Im using a new timing kit and ls6 beehive valve springs and gt retainers w my new cam as well as I finally learned about about the whole cam regrind process and how the base circle of a regrind will be different so custom pushrods are a must to set proper lifter preload and valve lash...
for right now..that is all..sorry for everything jumbled.. I believe the first paragraph I wrote in this thread included the words poorly prepared... :)
Discussion starter · #119 ·
Just mocked up..waitn on my heads to get back to put together..
Im freakin super happy to.say the least w how its going so far...i believe a new hood is in order.. I'll cut the one I have for now..too much to do before Street Machines comes to town to worry about that...
