and how do I determine the difference? My research has revealed these 4.6 and 5.4 supercharged Saleen's are prone to belt slippage. There is a fix which is an aftermarket tensioner. But is that the problem?
From my understanding to determine if it's clutch slippage be at a dead stop, put it in 3rd and let out the clutch. If it stalls the clutch is working properly. I tried that and it did stall. Is this a true and accurate test?
It seems to only occure in 3rd gear. Curising around 3k RPM and if I hammer the gas it takes a split second to get into power. I really haven't noticed my tack jumping around.
I don't hear the belt slipping or belt dust anywhere on the serpentine belt system. I have the Tremec TKO 600 with about 900 miles on the engine/trans.
Thoughts?
Thoughts?
