I have been researching ZDDP) in oil. It has been used as an anti-wear additive in oil since 1942. For environmental reasons the percent of ZDDP in oil has been reduced. The API Standard SN which came out in 2011 states that phosphorus (a part of ZDDP) must be between 600-800 ppm. Zinc content is slightly higher. But automobile manufacturers have pushed the oil industry to the low end to protect the warranty on their catalytic convertors. Mobil 1 full-synthetic 5w-30 (as tested by PQIA) has only 650 ppm of phosphorus even though the spec sheet says 800 ppm and the Mobil 1 full-synthetic 0w-30 that I've been running only advertises 650 ppm. Experts disagree somewhat but I've seen recommended levels for modern motors range from 700-900 ppm, 800 ppm seems to be the average.
I have considered changing to a European blend oil. They are rare in the US. At Walmart there is only one: Mobil 1 0w-40. 40 grade and thicker oils are not regulated by the SN standard. It is advertised to have 1000 ppm phosphorus and slightly more zinc. The parts store sells that and Castrol Edge 0w-30 European blend. I have not been about to find the phosphorus and zinc content of that oil. I think they are using something else other than ZDDP. I'm reluctant to use the heavier 0w-40 oil. I would still like to use the Mobil 1 0w-30 but I want more ZDDP in the oil.
Has anyone used Rislone Oil Supplement with ZDDP? Using their recommended dosage of 5.5 oz per 6 quarts of oil for 2000-2004 motors I calculate that the phosphorus (and zinc) levels would be about identical to European blend oils: 1030 ppm phosphorus with slightly more zinc. A lower dosage of 3 oz would put phosphorus at 818 ppm. That is probably what I'd use.
