Ok all,
I developed a recent problem at 18k miles - it only happens when I push in the clutch at speed - sometimes happens as the car is warming up, other times happens after cruising on highway for many miles. I push in the clutch, and the tach drops down to 100/200 RPM the car acts like it will stall, then the tach bounces back up to correct 750 RPM idle. If I feather the accelerator, I can keep the car from dying or sometimes it will die. I've replaced coils, IAC valve, plugs, fuel filter, EGR solenoid, fuel pump, MAF sensor, cleaned K & N air filter (it has screen in - I ensured I didn't over oil the filter). I just had the car tuned by a reputable tuner and the car ran just fine, it showed correct coasting idle and stationary idle settings, all the other datalogged numbers looked just fine - in fact, it put down a respectable 326RWTQ.
No check engine light - car runs perfect in every other regard - only happens when pushing in clutch at speed. Already used fuel injector cleaner, ran through several tanks of gas from a couple different gas stations. Turned the Traction Control off, symptoms still remain.
Driving me crazy......
