11.04 Stock Bottom End
3.7K views 50 replies 22 participants last post by  Marcs99GT
#1 ·
#6 ·
Very nice. I know 2 stock motor Vortech cars running 11.20s at 121-124mph. One of the cars also has over 100k miles.
#37 ·
What's ur suspension setup
Sent from my iPhone using AG Free
Lakewood 90/10 struts w/ 150# co's
MM caster/camber plates
Chromoly K-Member and control arms
Fox-body V8 rear springs (cut)
KYB AGX adjustable rear shocks set at "8"
Airbag in RR spring @ 10#
No front swaybar
No rear swaybar
UPR sub-frame connectors
UPR Pro Series Lower Control Arms, solid/spherical ends
UPR Pro Series adjustable uppers, spherical ends
Jegs Poly axle bushings
Torque boxes welded
No quad shocks
#23 ·
you mean first Jay then Dave. Jay has been running those cams for a couple years now
#11 ·
Nice!!
#14 ·
Thanks. The little hop is the 1-2 shift. I shift latter than Baz because of running the 28's.
#22 ·
Everything is stock except cams and springs. Heads or oil pan have never been off the motor
#26 ·
Detonation or lack of oil is what usually kills these motors. I've been spraying the car since 60k miles and have an awesome tune and always run 7 gts of good oil.
#27 ·
That's a bitchin run bro. Congrats.
