2003-2004 Mach 1 Modifications
70K views 33 replies 12 participants last post by  keanu4550
#1 ·
This write-up is a summary of modifications for the 2003-2004 Mach 1 Mustang. Bolt-on modifications in this write-up are defined as a modification that is an upgrade to an already existing part. Suspension upgrades are parts that may or may not be on your car already, help the handling of the car, and help launch the car with minimal problems. Power adders are defined as parts or chemicals that can be used to additional power that is not seen on a stock Mach 1 Mustang. Some of these modifications can be used on the 99-04 Mustang V6, GT, Bullitt and Cobra, but may not so be sure to double check if you own one of these other types of Mustangs. Lastly, this write-up is not the end-all be-all of guides for modifying your Mach 1. It does not include all modifications by all companies, but can be used as a guide when starting to modify your Mach 1. On a side note, if you plan to reach 400-450rwhp (closer to 450) please take extreme caution as our motor’s rotating assembly components typically don’t last much passed 450rwhp and need to be upgraded if more power is wanted.
Bolt-Ons
Cold Air Intake/Ram Air Intake (CAI/RAI)
Cold air intakes draw air from the passenger side fender well and increase the amount of air that is drawn through the throttle body. The air that is drawn from the fender well is more condensed (colder) than the ram air intake, but it eliminates the functionality of the Shaker.
The ram air intake increases the amount of air just the same as a cold air intake but the air is drawn from the engine bay so it will naturally be warmer than that of the CAI. The upside to the RAI though is that it keeps the Shaker system functional so some of the air coming to the air filter actually is cooler. JLT and C&L both make CAI/RAIs for the Mach 1.
Headers
Aftermarket headers allow more air to flow from the engine which in turn increases efficiency and horsepower. The amount of air you want to flow from the headers is up to you as there are three types of headers you can buy.
Long tube headers allow the most air to flow from the exhaust and give the biggest increase in power. However, they relocate the O2 sensors which in turn make them illegal on public streets. And an aftermarket midpipe or a modified stock midpipe is needed to connect the headers to the catback. American Racing, Kooks, BBK, MAC, and SLP all make long tube style headers.
Mid-length and shorty style headers allow a gain in horsepower, but not as much as the long tube style header. These headers are legal for street use though and an aftermarket midpipe is not necessary to buy with these headers. Bassani, and JBA make aftermarket mid-length and shorty headers.
Midpipe (X-Pipe, H-Pipe, Prochamber)The midpipe connects the headers to the catback parts of the exhaust. There are three different styles of midpipes and they are named by their shape. Each has its own unique sound. Apart from the three styles there are two types of each of these midpipes. There is the catted midpipe and the off-road or catless midpipe. The off-road (o/r) midpipe is less restricted than the catted midpipe which allows it to produce more power, but it is illegal for use on public streets because it eliminates the catalytic converters. If you are planning on a turbocharged system look into what turbocharger kit you want before buying a midpipe. Turbochargers require modifications to the exhaust manifold which sometimes renders the stock midpipe useless.
Catback
The catback is the final piece to the exhaust puzzle. Deciding on which catback exhaust system you buy will be up to you. Most of these produce the same power and the only difference is the sound that they produce. Bassani, Borla, Flowmaster, MAC, Magnaflow, Pypes, SLP, and Steeda all make their own catback system.
Water Pump
The stock water pump on the Mach 1 is a mechanically driven water pump. Stewart Components makes a direct replacement for the stock water pump (2-3 washers are needed to space the bolts though). The Meziere Electric Water Pump eliminates the need to pump coolant mechanically which creates more power than the Stewart pump, because the engine doesn’t need to turn the pulley on the pump as it is powered by the battery.
Driveshaft (Aluminum and Carbon Fiber)
FRPP makes a light weight aluminum driveshaft which reduces rotational mass allowing for a small horsepower gain, allows the car to move through the RPM band faster, and is stronger than the stock driveshaft. The carbon fiber driveshaft takes everything the aluminum driveshaft offers just a bit further as it is even lighter than aluminum and stronger. The only downside is that the carbon fiber shaft is considerably more expensive than the aluminum driveshaft. PST makes carbon fiber driveshafts.
Under Drive Pulleys (UDPs)
Under drive pulleys reduce the amount of power needed to power systems on the car which frees up more power to be put on the street. The Mach 1 comes stock with an under driven alternator so UDPs are not considered to be as good of a mod as they are on GTs. They are also linked to, but not proven to cause oil pump failure in Machs. Steeda makes UDPs that are harmonically balanced and are considered to be safer than the piggy-back style UDPs.
Short Throw Shifter
The short throw shifter is a replacement for the stock shifter in Mach 1’s with the Tremec 3650 (manual) Transmission. This mod allows a driver to shift into a gear with less effort by not having to “throw” the handle as far and find the gear easier than the stock shifter. MGW, Pro 5.0, and Steeda Tri-Ax are all types of short throw shifters that are available for the Mach. In this writer’s opinion, if you race your car at all this should be one of the very first mods you do to your Mach because of the T-3650’s trouble of shifting into 3rd gear.
Throttle Body (TB)
The throttle body allows more or less air into the intake and is controlled by the gas pedal. BBK and Accufab both make a twin blade throttle body that increase the amount of air into the intake. However, most owners of Machs will say that an aftermarket throttle body is not necessary until a power adder is added to the car as the stock throttle body flows well or a stock part.
Clutch
An aftermarket clutch will be needed if big power is produced on a manual Mach 1. Centerforce, SPEC, RAM, and Fidanza all make clutches for the Mach 1.
Flywheel
An aftermarket flywheel made from aluminum or billet steel is another upgrade for the Mach 1. An aluminum flywheel will allow the engine to rev faster due to a decrease in rotational mass. This also allows for a few horsepower to be gained from the addition of this mod. Centerforce, SPEC, Fidanza, and Ford Racing all make aftermarket flywheels.
Intake Spacer
The intake spacer is often confused among non-Mach owners with a throttle body spacer. This part is placed under the “lid” of the intake. This part increases the overall volume of air that can be in the intake and is the only part in the bolt-ons section that is not on a stock Mach 1. Paul’s High Performance and Roy on the Mach 1 Registry (2003-2004 Ford Mustang Mach 1 Owner's Club & Registry Website) both make spacers for the Mach 1. These spacers claim to have a 2-3rwhp gain along with a gain of 10lbs of torque.
Gears
Ford Racing Performance Parts and Motive both make gears for the Mach 1. Gears allow a car to accelerate faster (or slower). Machs come with a 3.55 gear ratio stock which is the highest of any 99-04 Mustang. Many Mach owners switch to a 4.10 or 4.30 gear ratio while some upgrade to a 3.73, but the 3.73 isn’t that big of a step up from the stock gearing. A majority of drivers consider a gear swap to be one of the best “bang for the buck” mod you can do.
Suspension
K-Member
The stock K-member or cross member on the Mach 1 is heavy and bulky. Aftermarket companies made K-members that are not as big, stronger, and lighter than the stock K-member. Sometimes a K-member is needed for a turbo setup or long tube header install. UPR and Maximum Motorsports both make an aftermarket K-member.
A-Arms
Like a K-member the A-arms are upgraded for strengthening purposes. Maximum Motorsports and UPR make after market A-arms.
Caster Camber Plates (CC Plate)
Caster camber plates are required on aftermarket K-member kits and more aggressive lowering springs. If you don’t buy CC plates with an aggressive lowering spring you won’t be able to align your car properly. MM, Steeda, and UPR all make CC plates.
Lowering Springs
Lowering springs do just what their name implies. They lower your car to get better handling and make the car look better. Mach 1s come with a mixed B-spring stock so don’t buy B-springs thinking you are upgrading. FRPP, Steeda, MM, and H&R all make aftermarket springs.
Subframe Connectors (SFCs)
Subframe connectors reduce the amount of flex your chassis encounters while driving resulting in better handling and launching of your car. Maximum Motorsports (MM) and UPR both make SFCs.
Upper Control Arms (UCAs)
Upper control arms allow your car to handle and launch better than the stock UCAs. There are two types of UCAs you can buy. Solid upper control arms are a direct replacement for the stock UCAs while adjustable UCAs require some tweaking. Adjustable UCAs are considered to be better as you can adjust the pinion angle to get the affect you want from your suspension. MM, Steeda, Granatelli, BMR, MMR, and UPR all make after market control arms.
Lower Control Arms (LCAs)
Lower control arms help tremendously over the stock LCAs. They allow your car to handle better and launch better than the stock arms to help reduce 60’ times on the track. Like upper control arms there are two types you can buy in the solid and adjustable versions. MM, Steeda, Granatelli, BMR, MMR, and UPR all make after market control arms.
Front and Rear Sway Bars
Sway bars are used to help stiffen the chassis in order to help with handling and launching the car. MM and UPR both make aftermarket sway bars.
Power Adders
Before I begin on power adders please talk to a qualified mechanic and/or tuner when applying a power adder. If one of these mods is added to a car it may end up being a catastrophic mistake if not applied correctly.
Superchargers
A supercharger is a mechanically driven power adder. It uses the engine to power a blower that forces air into the intake to produce more power than under normal conditions. There are also two kinds of superchargers for use on the Machs. The twin screw/roots style supercharger sits on top of the intake and under the shaker. This type of supercharger creates instantaneous power and it lasts throughout the power band. Kenne Bell is the only manufacturer that makes a kit for the Mach 1 however Eaton superchargers can also be mounted to fit.
The centrifugal supercharger acts like a mechanically driven turbocharger. The power created by the supercharger is “lagged” and builds up as the car goes through the RPM band. Vortech and Procharger both make kits for the Mach 1.
Turbochargers
Turbochargers pull exhaust gasses from the engine and send them back into the intake in a compressed form like a supercharger. The turbocharger does not require the engine to physically power it in order for it to work so there is no parasitic loss. The downside to a turbocharger is that there is lag, but it creates an extreme amount of power once it has spooled up. You can mount a single big turbo or a twin turbo setup on your Mach 1 to increase your power. HP and Hellion both make kits to fit Mach 1s.
Nitrous Oxide
Nitrous oxide (NO2) is laughing gas, but it is also used to chemically increase the power in a car. There are two different kinds of nitrous systems. There is the wet kit and dry kit. The dry kit sends nitrous oxide directly into the intake via the fuel injectors. The wet kit is sprayed into the intake. What system you want to use is up to you and you should do more research than what is provided in this article to decide what system you should use and how much horsepower you should add to your engine before adding it to your car. NX, NOS, and Zex are all reputable companies that make nitrous kits for Mach 1s.
#2 · (Edited)
Little change.
Nitrous.
The dry kits are sprayed into the intake path just like a wet kit. the difference is the dry kits make the injectors spray more fuel for the added oxygen that the nitrous is bringing in. The wet kits are sprayed into the intake path but they add the enrichment fuel to the nitrous spray so the injectors don't work any harder. If you run a 200 wet shot you aren't putting a bigger load on the injectors. If you spray a 200 dry you are putting alot bigger load on the injectors. make sense? the kits that spray at the injectors are called direct port kits. there is also a direct port setup that has a nozzle for each intake runner. colder plugs are a must, and if you plan on going over a 100 shot, then a tune is a must
#4 ·
The turbo is actualy two parts. The exhaust gasses spin the impeller on the turbine side which in turn spins the impeller on the compresser side. the compressor side pulls in fresh air and compress it, then sends it throught an intercooler and into the intake. The bigger the turbo the bigger the volume. i.e. bigger power, but at the cost of lag.
#5 ·
Thanks for the praises and thanks for the corrections/additions. If there is anything else that can be added feel free to do so.
#6 ·
Also, when considering turbocharging, twins does not mean more power. It usually will eliminate "turbo lag" and allow for faster spooling. There different types of turbos, such as variable vane or varibale geometry turbos. These don't need blow off valves, or waste gates. These spool faster, but don't build as much boost. Then there are ball bearing turbos, these build massive amounts of boost, but don't hold up to the heat as well.
#10 ·
Actualy the ball bearing turbo is pretty much all you find anymore. I am not sure if anyone puts the shaft on anything else. the best choice is a ceramic ball bearing turbo setup. These hold up under the extreme heat very well.
#9 ·
Nitrous oxide can also be used to eliminate turbo lag so that it is just like a roots/twin screw supercharger as far as the powerband goes, but with no parasitic loss.
#15 ·
No it actualy makes the turbo's work easier. Cool air is easier to compress and the the turbo will compress the nitrous charged air easier than it will atmospheric air. Same goes for any forced induction application. Not only that but a 50 dry shot will get you about 70-90 hp when used on forced induction because of the cooling effect and the easy of compressing it.
#17 ·
Well, I was taught differently from the guys at ATS Diesel Performance, and Pacific Peformance Engineering. I blew up an HX60, which is a huge industrial sized turbo, and several Aurura 6000's during beta testing. I was utilizing a 150 shot, to spool them up. One sent the housing through up into my hood, damn near going through it, and the other sent the compressor wheel into the ceiling of Trucks R'us Performance and Off Road.
#18 ·
But those are variable vanes are they not? I am not saying put a 150 wet shot thru them. I would say spray a 30-50 dry shot max on a standard turbo. I don't ever mess with variable vane so I wouldn't know what to tell you on that.
#19 ·
I'm aware of the effectiveness that nitrous has in cooling the intake air temperature. That is why I used it instead of water methanol injection, but when used to spool the turbo it seemed to have a negative effect. As long as the turbo was in the boost while spraying an issue was non existent.
#21 ·
I'll continue this tomorrow I have to hit the hay. I have vid at home of this, you can litterally see the compressor wheel shoot out of the exhaust stack like a ball of fire, and into the ceiling. I'm lucky that I had the stack on, and not the regular exhaust it would've taken someone out of the game.
#25 ·
That might be the kink in the deal. they practicly run on detonation so it might be jumping back down the intake and poping the compressor. who knows. Might have to do some studying on that.
#31 ·
Everything stays the same except you are limited on what intakes you can use and long tube headers. There are issues with spacing when using traditional 4.6 long tube headers on a 5.4. You can use shorty headers or the stock ones with a little modification.
You can't use a 4.6 intake with a 5.4 block unless you have an adapter plate. This isn't the optimal choice but it will get you by if you don't have the money to buy an intake that is made to fit correctly.
