28x9x15 slick with 4.10s
1 reading
3.2K views 25 replies 9 participants last post by  CJackson
#1 ·
So I'll be installing my intercooler Paxton novi 1000 here in a couple weeks. I previously install 4.10s but I was just curious if that'll be too much gear. Maybe running a 28" tall slick will compensate for the 4.10s instead of having 3.73s.
#2 ·
Using a 97% loaded diameter on a true 28" slick and CliffyK's calculator I get 118 mph at 6000 rpm for 4.10 gears.
Reference: PaladinMicro
Edit: I have a typo in the original post. I used 97% loaded diameter not 95%. I just fixed it.
#3 ·
Using a 95% loaded diameter on a true 28" slick and CliffyK's calculator I get 118 mph at 6000 rpm for 4.10 gears.
I might switch them out for 3.73s when I build my rear end completely. I imagine I'll be rebuilding it anyways cause I'm not to confident in it holding the power.
#4 ·
First put the blower on and see what kind of power the car makes. I've had 4.10's N/A and blown. Went from 101mph to 112mph. I use a 26" drag radial and max out 4th gear at the track. Right around 6300-6400rpm when I let off. If the car makes 360rwhp or less then you can stick with a 26" tire. If it makes a bit more then step up to a 27". You really don't need a 28" tire with the 4.10's unless you are pushing well over 400rwhp.
#13 ·
#21 ·
what rims are y'all running with your 28" tires and what offsets? I am looking into some 28" with slicks for our 2002 and want the tires nice and under the wheelwell
#23 ·
thanks...that seems to be the backspacing that'll keep'em under the wheelwheel...have you had issues with them hitting the quadshock? I am thinking of dumping mine anyways as I installed tubular LCA's after the rearend rebuild. I know some have gone with 5.5" backspacing but I haven't liked the look of those from what I've seen
#24 ·
Im also running a 15x10 w/ 6.5 bs. The typical size backspacing for stangs.
Have you dyno'd your car yet? It would help alot to know how much power you're putting down and at what rpm. For instance i rev my car to 7k with 410s and 26" slicks and hit about 6400-6500 through the traps. So for me 26" tires w/ 410s are perfect, but if you rev lower they may not be for you.
#25 ·
I use a 15x8 with 5.5 backspacing. You also want to run the smallest wheel/tire possible as long as the car hooks. Most cars don't need a 15x10.
