car work done so far: 4.10 gears, JLT intake, bama 87 race tune- originally the car is from south carolina and was driven with a 93 race tune, both from bamachips on an SCT tuner.
1. FUEL GAUGE: the fuel gauge is WAY off, about 90 counter-clockwise, i have to watch the electronic distance to E meter to know how much gas i have left. it does this even when setting the tune back to stock. as of today, i have used a full bottle or 'Seafoam' engine cleaner through the gas tank, as that was suggested. willing to try more if it would seem needed.
2. TEMPERATURE GAUGE: the temp gauge will sometimes go a bit off the hot end of the, and when i check under the hood, water hoses dont feel hotter than they should be, engine heat around the heads and what not isnt too hot either.
3. RADIATOR FAN: my radiator fan some times doesnt kick on by itself (when the car starts or when it heats up). it happens about 1 in 4 times i drive my car (which is frequent, but when it happens i have to kick Max AC on and it brings the fan on and stays on like it normally should.
4. REAR CAR VIBRATIONS: at high speed (about 70 and above) i get vibrations (they get rougher every mph), they feel like theyre coming from the drive shaft or rear axle. and the vibrations can only really be felt at certain degrees in RPM (unavoidable) but mostly when letting off the gas and slowing down (slightly or alot, makes no difference). any speed below that this car can be driven hard and has no other effects like this, if its pulling hard RPM's from a new shift, or burning the tires from first to second and then third, or even while cornering.
5. INTAKE SOUNDS: i have strange rustling sounds in my engine compartment constantly, they usually arent heard til the cars been driven for about 5 minutes. but it sounds like i have sand or really small pieces of plastic being blown around in the inlet system or something. i was guessing the flywheel because its so constant when it starts to happen, cant remember if it ever skips beats (stops for a second or longer), and i also havent seen if its power dependent, so maybe in the next half hour ill go for a drive to narrow some of this stuff down and do a couple free revs.
other than that, i love my car to pieces.
thanks in advance for the help, as this is a Very long read.
