5 lug swap question
861 views 7 replies 4 participants last post by  ryanw
#1 ·
Just thought of this and im sure the question has came up before, if I just plan on using the stock braking system from the fox, can I just throw on some 5 lug rotors from a lincoln and call it day for the fronts?
#3 ·
If you get the front rotors from a 84-86 svo mustang there only about $45 each.
The lincoln rotors are about 60-75 each cuz they have the ABS ring. So its pointless to pay more money for an ABS ring which you can use any ways.
The prices i listed above are from local parts stores... like pep boys, auto zone and oriellys
Maybe this will help
http://www.moddedmustangs.com/forum...om/forums/5-0-mustangs/261102-5-lug-rotor-question-what-year-model-lincoln.html
I cant say for sure every year lincoln has an ABS ring, but i know the 1990 year does.
#4 ·
#6 ·
Could I maybe modify the center caps, or the dust cap to make it fit, or is that way out of the question?
#8 ·
They may fit with out the dust cap on. Tyler had the same problem, he said that he machined down the rotor where the dust cap mounts ( a lot) but still when he mounted the dust cap, they woulnt fit. I forget what he did. Im guessing he left the dust caps off
