Assembling the H/C/I 4.3 v6
1 reading
21K views 141 replies 25 participants last post by  Nukka
#1 · (Edited)
going to post a day2day process of assembling the engine
the parts
paint on the block finished drying
first things first, cam install
the cam is from ssm, specs-224/230 .54/.54 114
cam and thrust bearing installed
balancer was next
then timing gear
next up, bearings
putting the crank in tomarrow
#2 ·
Very nice man, I like the color of the block.
#3 ·
Subscribed
#6 ·
they do, havent installed those yet. heres a pic when i tore the engine down. the chain gear slides over the top of the cam gear
#12 ·
if your talking about how long the build will last, hopefully real soon i only have a few weeks to get everything done. yeah i got a vortech v-1 system but i dont plan on putting it on till the engine is broken in a bit.
#13 ·
made some progress today. had to check the clearances for the crank sooo
put some bearing guard on first
cleaned up the 4.2 crank
one of the holes the machine shop drilled out to balance it
then placed the crank in the block
put the bearings on the main caps
used plasti-gage to check the clearance
everything checked out and was within tolerances, puttin in the pistons tomarrow
#15 ·
Looks like a fun build. I am excited to watch the progression of this.
#18 ·
What CR you going to be running?
#19 ·
stock, might be a lil higher because the heads were decked. i have a compression tester, so ill be able to give exact numbers later.
#21 ·
got some more stuff done. yesterday night i started prepping the pistons
piston rings
installed connecting rod bearings
FIRST PISTON IN!!
2nd
3rd
pic after all pistons were installed and rod caps were torqued
next up is the oil pan baffle, sump tube and timing chain and gears
#22 ·
Very nice
#23 ·
Looks nice. Are those hypercoated pistons and stock rods?
#25 ·
Sweet!!! Look forward to seeing it done. I want to see how it is as far as performance gains? I have heads I am porting for my car and I want to find a 4.2 and build a motor for it.
#28 ·
not sure about the weight, but i did pay an extra $160 to get ot balanced at the shop, didnt get a sheet but im sure i could ask for one.
#29 ·
ive been on a roll today on this build
got the timing chain and gears on, next the heads
here they are, ported polished heads with 3 angle valve job, and supersixmotorsports valve springs and retainers kit
steel head gaskets
Heads on!
pushrods
rocker assembly
#41 ·
steel head gaskets
[/IMG]
You had better check the head gasket installation. It sure looks like you
interchanged the right and left head gaskets. The blocked off water passages
are supposed to be in the front so the water will circulate through the block. If it's wrong as I believe it is here the engine will overheat very badly.
#32 · (Edited)
rockers and pushrods on with brand new lifters
valve covers on
aaannnd done for the day, tomarow im gonna be working on the oil pump lower intake manifold etc.
#33 ·
Are those just the stock valve covers painted silver? That looks pretty sweet and is definately better than paying for other valve covers.
#34 ·
yep, stockers painted in 'aluminum' duplicolor engine paint, aftermarket valve covers are stupid expensive
