Last weekend I decided to do some test-n-tune runs at the local 1/8th mile track in my Capri to see if I could get some decent times with the new engine, but I was having the same issues as last fall. When I shift gears, it falls flat on it's face for a second, then recovers. I was one of the first cars to run & immediately blew the tires when I dropped the clutch. Second pass hooked OK, but fell on it's face in 2nd & 3rd gear(9.04). Even though my floats are set plenty high, I decided to raise the front & back about a half turn. Bingo! finally a decent run, until I missed 3rd gear!!!! I did still manage a 7.88@87mph. So I must have some kind of fuel delivery problem(new Edelbrock pump, filters, etc.) My pickup in the tank is kind of rusted, so I suspect that's the problem. Anyway, now for the bad part. When I stopped to pick up my time slip, the gal at the timing shack said I was leaking something under my car, so I hurried to my pit & found a big puddle of green stuff under my car, plus I had no PS on the return road. I figured I probably lost a belt & overheated. Nope!! the water pump shaft broke off & put the fan through my aluminum radiator breaking the fan shroud & serp belt in the process. Crappy luck!! I've never seen this before. So, time for a new radiator, electric fan set up, water pump, & serp belt!! (also not very happy to pay $78 for a genuine Motorcraft water pump, only to find it a reboxed made in China part!)
