You need to tell us the rest of your setup. Assuming everything else is stock, that cam is too big for your setup.
At the very least, your heads would need new valve springs. Piston/valve clearance would need to be checked...
It's not a cam you just slap into a stock 5.0 motor and call it a day. You all the other stuff to compliment the cam, such as BETTER heads, exhaust, gears, compression ratio, intake.
