Beating head into wall.....
Hey guys, read my post directly above for some background on my issues^^^^^
First off, thanks to all of you who have offered advice to me so far, I appreciate it.
So I borrowed an Actron OBD scanner and hooked it up to my non-running car. It shows that there are no Diagnostic Trouble Codes and that the MIL (aka check engine light) is "off".
So, what the heck can I check next? I am guessing I should check for spark and if my COPS are good?
The car has been sitting almost 10 months now and hasn't ran since I parked it at the start of last winter. Here is a summary of what I've done so far:
-installed new fuel filter, and with filter removed I confirmed that fuel pump does pump gas out of the tank
-pulled the 4 plugs on the drivers side bank to try to blow out fuel (as if it was flooded), got pretty much nothing. The electrodes were pretty dark colored, but didn't look like anything too awful bad.
-cranked with gas pedal to the floor to try to relieve a possible flooding issue, nothign there. Method: crank for 10 seconds with pedal to floor, lift for 5 seconds then crank for 10 more seconds with pedal to floor.
-checked all underhood and under dash fuses, all good.
-held screwdriver to an injector and the other end to my ear while friend cranked motor, heard a definite rapid clicking.
-installed Marshall fuel pressure gauge in place of Schrader valve on fuel rail.. It reads about 36-38 psi when cranking, and around 34-35 psi when primed (KOEO).
-Ran an Actron OBD scanner to learn that there are no trouble codes and MIL is off. One thing I noticed though with the scanner is the cranking fuel pressure it displays was around 250-258 kPa, which pretty much matches what I learned from my fuel pressure gauge on my rail, around 36-38 psi when cranking. However, on the OBD scanner I notice the fuel pressure number does fluctuate rapdily while cranking. While cranking the scanner will read 250-258 kPa then for an instant it'll jump down to the 130's or 150's and then right back to the 250 range, maybe that's just the sensitivity of the scanner? Is that normal?
This thing will crank until the batt. dies, but it won't run. To me it sounds like it's not getting gas, but i believe my fuel presure is good, right? There are no obstrcutions in the air intake, so I guess I need to confirm i have spark. How can I confirm that I have spark?
ANy ideas what else I can check guys? Is there any other things I can monitor with the OBD scanner that can show me a possible problem? I'm really stuck here. when the problem first came up I thought I'd install a new fuel pump since it demonstarted those sympotms, but I hate to throw a pump at it if it's not the problem, so I'm trying to narrow down the issues here. Someone posted once that a bad alternator diode can cause a faulty cam or crank positon sensor? I'd assume that would throw a code, and since i have no codes does that mean my cps sensors are good?
Anyway, I'm at wits end, so please offer advice and I'll stay tuned on here and hopefully get this thing running.
Thank you!
