I've got a 99 cobra with a kennebell 2.1L being installed as I type... well, in the process of installation. KB claims to make 400rwhp on 5psi, and 426 with a larger mafs and chip at 6psi. I'm not saying that every car gets those numbers, infact kb has a disclaimer on 99-01 cobras, that timing could lose 30hp, but theyll swap out a pulley to get you that desired hp rating. They also claim to make more power on the 5psi kit than an 03/04 termi does stock with its 8psi eaton. A twin screw supercharger like the kb is claimed to be "more efficient" than the roots style eaton. I had a 99 v6 with ported heads and intakes and a camshaft, dual exhaust and gears, and I put a vortech on it, and got shitty numbers. Gooberhead bought it from me and is making close to 300rwhp on a stock engine (I believe it's stock). I was looking at a turbo for the cobra, and after reading everything, I decided on the KB because it provides boost throughout the powerband, where a centrifugal supercharger or a turbo needs a higher rpm to produce full boost. Although, turbo's are more efficient (like the guy above me stated) because they used exhaust gasses. There's a guy on the forum who has a kickass v6 that's turbo'd (but I hear he has lots of problems with it) I'd say if you go with anything, go for an 03/04 cobra. they're a bit more expensive, but the bottom ends are forged already, so there's no need to dig into them for a while. (I say a while, because no one is ever satisfied for long with their numbers) I probably made a mistake or 50 in this response, so feel free to correct me. So, that's my very long $0.02. enjoy reading it.
