1 - 9 of 9 Posts
04N20GT
· Registered
Discussion starter · #1 ·
I'm having trouble getting the output seal the last 1/4 inch or so into the tail shaft. Anybody know a cheap way to get the seal seated. Right now, the driveshaft yoke will only go on about an inch or so one the threads line up. I think it's cause the seal is not fully seated and it is catching the yoke.
get a slidding hammer or a bearing puller
like 5/6 bucks at harbor freight
---------- Post added at 07:50 PM ---------- Previous post was at 07:45 PM ----------
or just grab it with pliers n pull it out if your going to replace it
Try using a socket and a hammer to lightly tap it in.
Discussion starter · #4 ·
I'm trying to put the new one in all the way.
I'm pretty sure I used a wheel hub socket and lightly tapped it in with a rubber mallet. Just try different sockets and lightly tap on it. (I had trouble getting it in too)
2x4 with a hole cut so it won't touch the rubber part of the seal, and a second one without a hole screwed to that. Hit it in the center and it should drive it in evenly.
1 - 9 of 9 Posts
