How to do a wheelie?
17K views 66 replies 31 participants last post by  flattusmaximus78
#1 ·
How much power do I need to do a wheelie?
#2 ·
Upper and lowers and subframes, take weight out of the front and add some to the back, and put some slicks on and a stock mustang will have enough power to pull the wheels... That said, wheelies are pointless. It's just energy wasted in lifting the front of the car that could be used to move the car forward. When you see a car doing a wheelie, it's not going as fast as it could down the track.
#8 ·
aluminum heads will get rid 60 pounds, fiberglass hood ect......
#20 · (Edited)
I'll bet he's got weight in the back of that, or he poured some VHT down, or he's been doing that in the same spot laying down a shitload of rubber in the same spot to hook on. (which looks like the case) Believe me, it ain't happening at a stoplight somewhere. I have a friend who had a 1500hp alcohol car that ran bottom 5's in the 1/8 and he took it out on the street a few times in front of his shop and never got enough traction on the street to get the wheels up.. and that car weighed less than 2k IIRC, full tubs and slicks.
Edit: no that weight can't be right now that i think about it, but it was a tube frame chassis with a firebird body on it and that was it so it was definitely light... and come to think of it, that hp figure can't be right either. The guy told me this and I never really thought about it but 1500hp should have been faster than it was for what it was... regardless. even if it had 1000 hp, I def saw it run bottom 5's and I def saw it not be able to lift the front on the street.
#23 ·
A buddy of mine runs a 66 Malibu 2 door wagon with a 540 on spray, he ran that on the street until he hit the 8's. He'd pull the tires on the street no problem, and used to drag the bumper at the track. Running a 32X16 slick on the street helps, lol. Plus, there was next to no weight in the front of the car, fibreglass front bumper, hood, fenders, etc. and lots of weight over the rear with the cage, full glass, etc.
#30 ·
On the street its not gonna happen on most cars that dont have the chassis backhalfed period. Otherwise you will need an insane amount of HP and DOT slicks. On the track its fairly easy with boltons, N20, Steep gears and big slicks.
#31 ·
for a bone stock car you'll need a couple of things to pull a wheelie. torque, slicks, a strong rear end, weight reduction/weight transfer, and suspension to catch all the traction you can. you'll need to build your rear-end changing the axles to at least 31 spline along with a posi 31 spline differential, remove all your a/c components, move battery to the back, remove front sway bar, remover the bumper support, remove egr, remove windshield washer fluid tank, and that should be enough to pull tires up or it was enough for me with almost full basic bolt ons especially 4.10 gears or steeper. now getting suspension work done will increase traction, prevent wheel hop putting more torque to the ground get some full length subframe connectors, quad shocks and shocks, replace the stock subframe connectors with polyurethane bushings or get a set of control arms, some traction bars, launching springs, and some skinny tires for the front you'll pull a pretty good wheelie for a full bolt on car. i would stay away from cams, your wanting low end power not top end to pull a wheelie. my car can bet a ls1 swapped into a datzun that weighs 2,000 pounds from the launch by almost 3 tenths at the 60foot but by the 1/8 mile he will walk me and beat me by 4 tenths at 1000 foot. low end power is where is at to pop wheelies. plus cars with good low end power are fun to feel when you take off that fast.
#34 ·
Geeeeeezus!!!!!!!!!!!!!!!!
Not to mention the thread bump is full of WTHF (what the holy ****) information.
---------- Post added at 02:19 PM ---------- Previous post was at 02:17 PM ----------
My car has a cam, and it does wheelies. I guess I'm doing them wrong.
