how to make trunk stop rattling ?
2K views 9 replies 6 participants last post by  Xzavier247
#1 ·
i have a 96 GT and in the trunk i have 2 JL audios with MTX amp sounds amazing besides from the out side of the car it rattles a lot any suggestions?
#2 ·
If its the license plate your talking about then you could always put little pieces of felt behind it.
If its the whole trunk probably not much you can do. Dynomat on the inside might help but I don't know how much if any
#3 ·
You can use sound deadener like dynamat. There are cheaper brands like fatmat and hushmat. Also if you carefully use great stuff expanding foam in your trunk lid under the braces that helps. I used great stuff and fatmat on my old car and it helped a lot. Very little rattle with two 15"s on 5000wrms.
#7 ·
what I found that helps too, is proper tuning...
#9 ·
if your really on a budget, try seal n peal at home depot or lowes. 20 dollars for a big roll. Works really great and theres a lot of it and its inexpensive. There arnt any foul smells of tar or anything everything is awesome. it really works.
