Max hp with 19lb injectors.
14K views 12 replies 4 participants last post by  fogged306
#1 ·
Well i think the title says it all...what exactly is the most hp the stock 19 punders can handle? Im upgrading my fuel pump to a 190lph but was just wondering about the injectors.
#2 ·
  • 500cc per minute is approximately equal to 49lbs per hour which is equal to approximately 100hp.
  • lbs/hour = cc per minute / 10.5
  • lbs per hour = HP / 2.04
  • cc per minute = lbs per hour x 10.5
  • cc per minute = HP x 5
  • HP = cc per minute / 5
  • HP = lbs per hour x 2.04
#5 ·
heh. I know that...but im going to gt40p's with 1.7rrs and cobra intake...can I make it with the stockers? Im also going back with a 75 shot and a dyno tune. sooo looking at around 350 to 375hp...hopefully
#7 ·
ya...but I figured I would just be close to the max. Think ill be alright?
#11 ·
Well i think the title says it all...what exactly is the most hp the stock 19 pounders can handle? Im upgrading my fuel pump to a 190lph but was just wondering about the injectors.
The formula is:
Maximum HP = (Injector rating x duty cycle x no. of injectors)/Brake specific fuel consumption
Assuming a duty cycle of 85% or 0.85, and a BSFC of 0.50, we get the following:
Maximum HP = (19 x 0.85 x 8)/0.50 = 258hp
That's only a rough estimate but it gives you an idea. How's that for dirty talking? ;)
#12 ·
heh thanks...Means im gonna need 24 pounders. Damn. But i know there is a guy running around on here with tw heads and the stock injectors. I could prolly get by on the stockers if I didnt add the nitrous right away. Then when I did add the spray just upgrade the fuel too.
