Well i know lean or pre ignition would cause this to happen, but it only happened to #8 spark plug, All the rest look fine.
I have a couple friends who think my return fuel setup is wrong and may have caused only number 8 to melt from not having fuel. The way its setup, I have the feed line comimg In on the rear of the drivers fuel rail, then crosses over the alternator into the front of the passenger fuel rail and exits out the rear fuel rail into my regulator. The regulator has a return line going back to the tank. Idle is 40psi.
What do you guys think?
