motor mounts
1.7K views 21 replies 10 participants last post by  -Joeyy-
#1 ·
Are the motor mounts the same for a 5.0 and a 351? because it seems like my drive train leans to the right and i dont know why.
#5 ·
hmm...do you have subframe connectors? Sounds like your body's twisted as ****. Measure the distance between the ground and the top of each fender opening with the car parked on level ground. That'll tell you how bad it's twisted, if it is. ANd bad motor mounts that have been bad for sometime make it worse.
EDIT: wasn't this the car you saved from the crusher?
#6 ·
if the mounts themselves are good you can loosen them and lift it from under it with a jack ad shift it. but if they are stock mounts i bet they are bad.
#7 · (Edited)
yes this is the engine that i saved from the crusher but i found this shell to put it in.
I doubt the frame is twisted but i will go measure what you said right now to double check...
I gota find a place to buy harder mounts so it doesnt torque over so bad :(
EDIT: yeah i have subframe connectors and a 8 point cage. the car has a lot of support.
#9 ·
IMO solids suck. they are great if you are just gonna drag the car but not if you want to drive it on the road. the vibrations are TERRIBLE! and i also blame my solids for cracking my bellhousing on my AOD in half.
#13 ·
thats why you get the rubber tranny mount cause something needs to move.
poly mounts would be optimal all the way around but they are so damn expensive..
#11 ·
I would go with the solids. I bought the cheap ass ones for my car off eBay and there is hardly and difference in vibrations there cheap as **** and strong as he'll I've put like 14,000 miles on mine with like at least 6 bottles worth of 200 shot. But I have a t5 so I'm not sure on the bell housing thing
