Decided to try something a little different. I sold my Bassani mufflers and I am going with a 2 chamber design. Only problem is I hate 2 chamber mufflers with O/R X pipes. So I am converting my x to a chambered design almost like a prochamber. After some fiddling on the computer with designs, I will be adding some baffles inside. The theory is to try and equalize the exhaust pulses and help scavenging. Whether it will work or not I wont know till the end but it should sound way better than an O/R X.
My x
2.5" stainless exhaust tubing
Tubing cut in half and test fitted
Test fitting bottom plate
used the plasma to cut some of the old x out, getting ready to tack new sides in place
Sides tacked in place and also removed part of the mid that will be in the chamber, will cut other side off once top plate is welded on
Top plate tacked in place.
Once I get the top plate welded in place, I can make the end caps, weld them in, then make my baffles and install the bottom plate
My x
