Hey everyone-Just installed a professional products 75mm TB and plenum. Took it for a test ride-seems to have better throttle response and get up and go. Problem now is the check engine light-error code is P0122. Throttle Pedal, Position A CKT, LOW INPUT Short CKT. I did have problems hooking up the throttle cable to the new TB, bit it seems to run ok. Anyone have any ideas? Is this because I hooked up the throttle cable wrong or is this a tuning issue. If anyone has installed this product and can get a pic as to how the throttle cable is supposed to look like when connected I'd appreciate it. Thanks
