In short i love the "theme" if you will of N/A power, it's so cool to be able to out run cars that have a lot larger motor and more cubic inches than my car and to be the under dog. I am starting my research now but will probably not start on anything for a while but i want to start looking up some options and gain info about how to get more N/A power out of these little 281's.
I am trying to see how much a build would be for a forged shortblock and a good set of heads with a bump up in compression. I already have some good N/A cams that i can reuse for the build. What would be best for a budget on the heads? Send mine off to be worked or get some MHS or Trick Flow heads? What compression ration would be good for N/A power? Here is what i was thinking about for a build with my vague knowledgeable of how to build a good combo. I will keep spray on the car after my build is done FYI but mainly looking for power N/A.
*Needs*
Looking for around 320-350 WHP N/A
Around 500-550 WHP reliably off some spray
Still be able to have great driveabilty
*Build*
MMR 600 shortblock with a upgraded oil pump
4.6 or 5.4 shortblock?? (whats the good & bad? The 5.4 is cheaper, is it a direct swap?)
24-28 LB injectors?
Victor JR lower intake
Heads heads heads i have no idea????
Cams and springs are in my stock heads right now
Just get a BAP for my SVT pump, it was only at 80% Duty Cycle when i put down 385 WHP without a BAP
What else do i need?
I would like to know what you guys would suggest in a N/A build and any info, tips or anything would be appreciated. Thanks, Baz.
*Needs*
*Build*
24-28 LB injectors?
