Questioning of a dyno tune?
767 views 3 replies 3 participants last post by  qwkpny9150
#1 ·
My 04 Cobra has a dyno tune on it right now and I have the the tuner with the stock tune and the dyno tune on it. I just got an off road x pipe, with the tuner off the guy and he never installed. If I put the the pipe on it will it screw with my tune? I know it should throw a code, can this be taken care of with the tuner, or if i go in there and mess with it will it bomb the dyno tune?
#2 ·
should be fine. You will have less backpressure in which the eaton likes so you might want to have the tune a little updated, but you should be ok, and yes you can turn off the rear o2's with your tuner.
#4 ·
i figured that, i wasnt worried much about the tune itself getting messed up by installing the pipes. more worried if i went in there to see if he had the option parameters to kill the light in there, i was afraid to open it up to find out. I'll just try the non fouler trick first for a while then once i do take it to the dyno ill just get him to kill it from there. Im new to this hole tuner thing considering i came from a foxbody, and what little bit i read when i just had the lightning
