I installed the Raxiom sequence tail light harnesses with the Raxiom LED bulbs and got the Raxiom modified turn signal flasher on my 99 v6 stang. Problem I'm having is when I turn the left flasher on its fast and when I turn the right flasher on its slow. I switched both harnesses around and still had the problem on the left side so I know it can't be the harnesses. When I put on the four way flashers they are both slow like when I turn on the right flasher. I got a replacement modified turn signal and same thing is happening. Can someone give me ideas on what I need to look for? There be a short in the wiring somewhere?
