Well after trying to chase down my vibration at high speeds, guy at work told me to check my axles as one might be bent just a small amount. so i threw a dial indicator on both my axles(with the wheels/rotors removed ofcourse) and the first side fluxuated about .004, the second side fluctuated about .012. at that point i thought it might be the bearings so i swapped the axles side to side and the axles kept the same readings they had so it's not the bearings. could that extra .008 be enough to cause a vibration over 95 area?
