Replacing Caliper/Bleeding Brakes
482 views 2 replies 3 participants last post by  C MY 4D
#1 ·
My cobra has a seized up caliper in the front and has to be replaced. First off, which is the best brake bleeding kit to use (I tried the two-man pedal pump procedure last time..guess what..it still does'nt work if you dont know what youre doing). Second, since Ill only be replacing the two front calipers can I use these brake bleed kits to bleed only those two lines or does the entire system have to be bled?
