1 - 3 of 3 Posts
stew112
· Registered
Discussion starter · #1 ·
I just installed my new Strange Engineering Struts + FRPP c-springs... The struts are 10-way adjustable. Anyone else have these and ideas of what seting to set them at? It just snowed a **** ton! damn chicago weather!!!!!!! I cant wait to try them out and my car looks bad @$$. now its got a mean stance!
You should find out what the damping force is for the different settings. Then adjust to match your spring rate. Or, start at one end and adjust from there. Ideally when you go over a bump, your car should go through one full bounce and then settle. So 1.5 wave lengths. So You hit a pot hole, the car goes down, bounces up, and then comes down to the road. That is when it should stop. It shouldn't stop early or bounce againl. It should just settle. Hope this helps you out.
Discussion starter · #3 ·
that helps out a ton! thanks man. im in chicago area so there are pot holes every 2 feet. thanks again
1 - 3 of 3 Posts
