04 Mach I, 4.6 DOHC, 36k miles, stock. After the engine is warmed-up for a few minutes, it develops a ticking/knocking type noise that sounds like it's coming from the driver side chain cover. I replaced the guides & tensioners but no change in the noise. Went back in and inspected/cleaned the oil passages in the head, the feed tube & passages to the tensioner but it all looks OK. I even ran the motor with the left valve cover removed & listened with a stethescoop by all the lifters & springs. The the noise still seems to be coming from the frt of the engine. The oil pressure is good. No broken valve springs, loose lifters or rocker arms.
What an I missing here?? Any help is greatly appreciated!
