Twin Turbo Mach1
15K views 27 replies 9 participants last post by  98Cobra_sleeper
#1 ·
Hey guys, I am interested in putting a twin turbo on my 2004 mach 1, similar to the "hellion hellraiser" project car which can be googled, I was recently looking up twin turbo kits a couple of weeks ago and am looking to order them soon, I was just wondering if anyone in this forum has ever done this to a '03 or '04 mach 1 and would be able to give me some pointers on what else I should upgrade to make sure the engine can harness the extra power at higher RPM's, from what I understand the mach 4.6 has a higher compression ratio than than the GT 4.6, is this true? and is the compression ratio high enough to withstand a twin turbo? help me please, i am also looking on americanmuscle.com to try and get some cams and a 90mm throttle body ordered and installed.
#2 ·
Ok, I'll point out a few things that I notice here... "90mm throttle body": They don't make a T/B that large for the Mach 1. Maybe you're thinking of a 90mm MAF sensor?
Second, the Mach 1 engine's compression ratio stock is 10.1. I'll let everyone else go into detail regarding compression rations, the stock Mach block and what's needed for a twin turbo setup.
#3 ·
yeah you were right about the 90mm MAF I was looking at both and started mixing apples and oranges, the accufab throttle body is what i was going to order i think it measures out to like twin 62mm ports or something like that.....
#6 ·
yeah swervo has done it, go to youtube and type in TT mach 1, he's video will come up.
the stock compression on a mach isnt good for boost, or safe for it more or less, id suggest obtaining a lower compression ratio.
the mach 1's motor isnt exactly all that good for boost in general, the crank, if your a manual mach is about the only good part of the bottom end and block
check out HP performance, there turbo kits seem to be pretty sound
#7 ·
Talk to M1M or DanB on the Mach1registry. They can give you some really good info on this. They do this for a living... when I have the funds, I'm taking mine to them for a TT setup. But I'm also going with a new engine, drivetrain, suspension, etc... everything. If you want a power adder, you need to educate yourself on beefing everything up to handle the power. Our engines are good to over 400 HP, but the internals won't be able to take much more than that (average). There are some freaks out there that manage to hold more power, but I wouldn't chance it on stock internals.
#8 ·
I would like to be able to harness at least 16 PSI boost per each turbo if thats possible, ive never done anything like this bfore so I wouldnt honestly know where to begin, what do you think is reasonable, I would like over 600 HP which i know is not hard to achieve with a TT setup
#11 ·
yup as stated that compression ratio isn't the best for turbo'd car. if you stay low boost you'll be okay, but everyone with boost knows that isn't humanly possible.
#12 ·
Hey, I'm the guy with the Twin turbo'd Mach. For turbo kits, I'd choose Hellions Hellraiser kit over the HP kit. I have the HP kit and it alright, but could be alot better. Hellion comes with everything you need, including a scavenging pump, which is a must for turbo's mounted that low.
Now for the Mach engine. You'll be fine running low boost, maybe around 7psi or so and it will be fine, with a safe tune of course. That's what I'm doing right now. The best thing would be to build a bottom end for it. Also remember to get the supporting parts for all that power you're going to have once the turbos are installed, ie clutch, fuel system, rear end, suspension...etc. All that power is nice, but if you can't put it to the ground, it's useless.
#13 ·
Hey man, saw your video on youtube through futuremach's refference, very nice car you got, as far as the engine goes when you said 7 PSI would keep me on the safe side, is that on stock internals?? also your front end, is that a completely different bumper you used for the intercooler and turbo space? mine looks different so I was just wondering if that setup offered more space to work with as opposed to stock. The last thing is could you please explain the building a bottom end ? are you talking about the rear gears and suspension?
#16 ·
Yeah, I had over $15k invested in and engine to handle over 20psi. It gets costly when you're trying to push those numbers. If I had to do it all over agin I would've bought a preassembled shortblcok instead of starting from scratch. It's so easy to go overboard on these motors. Check out Livernois, and MMR they make some good stuff for reasonable prices.
#17 ·
HP's kit
hey, i wouldn';t recommend HP's kit. Im in the middle of installing one now. They sent watercooled turbos apparently by mistake, no oil lines, oil fittings that dont fit, no turbo gaskets, and the boxes that the turbos came in had Texas Hot Rod written on them. i have no clue why, and they dont' seem like they want to help me figure anything out. They told me to just plug the water ports on the turbos. i called garret, and they told me if i do that i'll destroy the turbo and void the warranty. it seems to be a 'nice' kit but you may have to scramble for parts. it really amazes me that they told me my turbos shouldn't have been watercooled. why wouldn't they know what they sent out? bewilderes me.
#19 ·
damn man sorry to hear that, i hope they get their **** straight or they wont be in business much longer. thanks for the heads up
#24 ·
The bearings in my factory pump shattered, causing my engine melted down. This was caused by a minute vibration from my UDP's it wiped out the whole lower end. I made a thread explaining it in fiurther detail.
Anyways, like I said I built a motor for a twin turbo setup, and I had $15k into it, and that was with no turbos, aftercooler, and other misc bs for the install. It can get really expensive. I had a longblock that could support over 1000hp though. I went way overkill, but it was done right. It had the best of the best parts.
