Vacuum Line question
700 views 3 replies 2 participants last post by  Skargon
#1 ·
Ok did the search thing pulled up a little info but still no answer. AC output is stuck on defrosters. OK vacuum line issue. Tracked vacuum line down and found a broken line that runs parallel to firewall. Its on the drivers side and i read that this line is one that could cause the problem. My question now is where does this line run I cannot find where it goes on any vacuum line diagram it just shows it dead ending.
#2 ·
:dunno Had this same problem, Fixed it with this..
In that circle, is where my vacuum like ended, Their is a slot on that piece that says.. "A/C" and I plugged it there, and it works now. Hopefully it will for you too. :rockon
#3 ·
thanks i will check that out this evening and to jsut double check it is the small vacuum line your talking about not the big rubber one? along the firewall you can see a small one under the big line and that is the one I found broken
