what color is the dimmer wire in the instrument cluster
9.8K views 5 replies 4 participants last post by  competition orange
#1 ·
reason i ask is im installin gauges an i want them to dim with the factory stuff i have checked my chilton wire diagrams just cant seem to find it
#3 · (Edited)
If you remove your headlight switch and disconnect the harness, the large grey wire in the center of the connector in the rear of this unit is the switched positive wire. Connect the switched power wire from your gauges to this wire. I found a splice tap to be great for the job. Then on the right you'll see a screw running into a horizontal pillar. Just connect the ground wire to this screw and you'll be set.
I actually just did this yesterday so if you need any help, let me know :)
EDIT: are you doing the entire gauge cluster or overlays? If you're doing the entire cluster, it's a orange/white wire. There's also one running to your radio, which may be the easiest to find.
#4 ·
mine was different? i used the "dimmer wire" to power my mechanical boost gauge and fuel pressure gauges lighting. i spliced into the dark blue wire with a white stripe on it coming off of the headlight knob. i did the same with shaun's boost gauge and it worked perfectly.
