What is this peice?
645 views 7 replies 5 participants last post by  89lx
#1 ·
I have on of these on the return line by the tank, and its leaking
can I replace it witgh this?
#3 ·
yeah im goign to get a new line eventually, for nwo i had to cut it in two palce and patch it using rubber hose and clamp, I cant access the whole thing without a lift, and my budget doenst permit it at this time. Can I do that as a temp fix?
#6 ·
Damn that thing is rusted..
Not sure about the barb fitting. Depends on the amount of pressure going through it.. after all it did make the actual pressure fitting leak..
If it is a return line, it would have more fuel going thru it/more pressure at LOW RPM (less fuel used, more returned to tank) since the pump runs at a constant speed...
#8 ·
just go to napa and by a new quick connector and borrow the tool to put it on,15 mins the most on ur bk in the drive way :yes or you can cut it off and get a steal barb that jams in the line and on the other end it take a hose
