1 - 20 of 61 Posts
evil02gt
So i finally decided to ditch the centri and stock shortblock. Went with a forged bottom end, MHS heads,cams and still deciding on turbo. My question is what rear gears and tires should I run? I should be around 650-700 rwhp and running it through a 5 speed trans and will be using a n2mb. Rear rims are 15x10 and fronts are 17x4.5. Any help is appreciated.
Depending on what you really want out of the tire (street/strip/both) I would go with a qtp if only strip. Street and strip I would look into the Mt radial pros or the Mt et street r. 275/60s. Gears depend on your overall goal but 3.73 would be fine.
It's no longer a daily driver but will drive it on weekends. I will probably pick up a set of daily wheels and a track setup. At the track I have to run a dot approved radial. I want to get as wide a tire as I can . The 315-35-17s I had on the rear before looked good. I would like to get something at least comparable!
I
Why would you need a dot radial for the track? After living in va for 6 years, I know vmp and colonial don't care about tires as long as they aren't dry rotted or completely gone. Qtps are dot approved but are not a radial. A radial will not be good with a stick car fyi.
I checked and can run any dot approved tire so the qtp is acceptable. Now what gear and what size tires? I have heard run everything from a 327 gear to a 410.
What are you building your car to make power to or what are you planning on spinning it too?[/QUOTE
I'm looking to make between 650-700 with the turbo setup. I will call MHS and find out what the peak rpm range is for the cams I have
I'm looking to make between 650-700 with the turbo setup. I will call MHS and find out what the peak rpm range is for the cams I have[/QUOTE
Your cams can go to 7500RPM but you wont need that
Discussion starter · #11 ·
Well just basing it off you will be going turbo amd the power you hope to make I am assuming you will spin it to around 7k. I would go 28" tire with 3.73s or 3.90s. If you are planning on more power later, 3.55s wouldn't be bad and may be better if it's more of a street car.
...I would go 28" tire with 3.73s or 3.90s. If you are planning on more power later, 3.55s wouldn't be bad and may be better if it's more of a street car.
If he runs it down the quarter with over 700 hp he'll run out of gear running a 3.90... assuming the car loses a little weight. With a turbo car I'd say 3.55's would be the best bet. Once you get the power, have you ever seen someone say "Hmm, that was fun, now I want to go SLOWER!" No. Even if he doesn't run out of gear with 3.55's on this build, he will the next time he ups the power level.
I don't think you'll be happy with the 3.73s or 3.90s on a turbo car.
Discussion starter · #16 ·
I will probably go with 3.55s. seems to be the happy medium. With 3.55s would you still run a 28" tire? What exact size would you guys run with a 15x10 rim?
At 700 hp he wouldn't even be close to running out of gear with a 3.90 if he spun it to 7k with a 28" tire. No way he would be trapping 150+. Hell....he wouldnt even run out of gear with a 4.10 with that setup. 700 hp at full weight will trap high 130s
I went 410, then 373 then back to 327.
1 - 20 of 61 Posts
