Hey all, I'm new to the forum so be nice to my ignorance.
I joined specifically because of a problem I'm having and I dunno where else to turn. I've got a pretty heavily modified 02 GT (which i kinda turned into my own Boss 281 theme). I don't use it as a daily driver, but I do have some issues with the rear wheels. For about 2 years now I've had 17x10.5 rims with Goodyear Gs-d3s on them in the rear and have had little problems with rubbing (usually only happened when I was racing the car). Recently however they began to make rubbing-like noises anytime I made a right hand turn (sharp right, typically from a stop) as well as sharp left turns. Even more scary, i started to smell burnt rubber every time I stopped driving the car (coming directly from the back wheels)
So I went and bought 5/8ths wheel spacers from mustangwheelspacers.com and had them installed. It did a good job at leveling out the tires to the edge of the wheel well, and stopped the rubbing when giving it a lot of gas. But it did NOT stop the rubbing noises when making sharp turns. It also seems to only make these noises after the car has been driven for about 30 minutes. The car's performance doesn't seem affected at all by any of this...and when I look and feel the tires I cannot see any evidence of rubbing (for example, the small rubber hairs that stick out are all still there...none are shaved off). As well, when making a sharp turn but NOT giving it gas...another type of rubbing sound appears to come from all angles of the car (I can't really determine if it's front or back).
My question is basically this: Does anyone know if it is possible that despite the spaces, somehow the wheels are rubbing against the quad shocks, or the exhaust? And if so, what is the way to rectify this?
The car's suspension mods and exhaust mods are as follows:
-eibach lowering springs (standard)
-MM rear sway bar
-5/8" wheel spacers for rear
-Flowmaster American Thunder exhaust system
-MM tower brace
-MM subframe connectors
-stock shocks
-MM rear sway bar
-MM tower brace
-stock shocks
