13,581 - 13,600 of 20,261 Posts
Lowering it alongside the arms. It is my daily driver and I am going for more of a corner carver than drag.
I am putting a Watts Link in instead of a panhard bar and I live locally to BMR so I get the local discount already. :)
Also, I'll be replacing shocks/struts/springs all at once.
Adjustable upper with spherical bushing, Adjustable lowers with front poly bushing rear spherical, relocation brackets, upgraded upper mount, swap to grade 8 true 14mm bolts to eliminate clunking, you should be happy with that set up
Thanks for the info guys!
---------- Post added at 06:15 PM ---------- Previous post was at 06:02 PM ----------
Also, I'll be replacing shocks/struts/springs all at once.[/Q
man that must be nice lol.. hah what shocks, struts and springs you going with
BMR springs and Koni yellows.
Blacked out fogs and tails. Springs and gears in the trunk waiting for time to install and them hopefully cams in next weekend. Blacking out the side markers will finish out the mods
I ordered wheels and tires today! Wheels are Enkei PF01's in 18x9 with 45 offset. Tires are Hankook RS3's in 265/40/18.
Before anyone asks the dumb question... because racecar. The class I race in has a maximum wheel width of 9" wide and a maximum tire width of 265. It sucks, but that is what I have to work with.
That said, I'm excited. the PF01's are 19.3lbs each and combined with the 265's I will drop 35lbs from the car and all of it is unsprung rotating weight! WINNING!
I'm giddy as all get out! :bubba:
Got a $112 ticket for having a modified exhaust :/
what ya doing with the stockers?? how much...lol could pick them up even
I bought my 2005 GT today. Have to wait for more for some mods :( but i got one
I'm keeping the stockers for DD/Rain wheels/tires. The Star Specs will serve that purpose reasonably well. I just needed to save them so that they DO work in the rain because the new tires, wont... well, at least not very well. Once the Star Specs wear out the stock wheels will get shod with some Continental ExtremeContact DW tires and I'll DD/Rain those!
Besides, my stock wheels are NOT in good condition, you wouldn't want to buy them from me anyway.
Im going to change the oil today, possibly swap the valve covers so I can Re-do mine, and maybe repaint the brake calipers.
Any tips on how to keep the brake fluid in the system when I remove the caliper and have an open line? putting a bag on it only helps to catch the fluid as my brakes drain out all over the driveway
It's gonna happen unless you have a cap on it. I've seen people clamp the line, but you wouldn't catch me doing that.
Why not just leave them on whe you paint them
Found out that the JLT RAI fits with NO PROBLEM under a Steeda 2 point strut tower brace. Good news for Mach 1 owners! :)
Sorry the engine bay is so dirty...haven't gotten around to the spring detail just yet.
Eibach Pro's finally installed. Perfect imo, almost went with a mroe aggressive drop but glad I went with the Pro's. Ride is almost stock and its plenty low for me.
Couple of quick cell pics as it started to storm right after we finished.
installing the bbk tuned shortys today, i will update this evening when im all done to give a seat of the pants dyno results.wish me luck with the install ,im not a mechanic .lol.!! but i will be using dimoras hedder write up ,and tips from members.
Got my windows tinted today. Did my full paint correction yesterday and the day before. Looked perfect until I hit a gravel road on the way home. Will get pictures later if I have time to wash her again.
