This is one thing that worries me. I went with 295/45/18 NT555s as a better all-around tire option as I'm guessing NT05Rs or NT555Rs would be horrible if it's a cold or wet out. I still plan on getting 4.10s (i'm doing the panhard brace first) but I don't wanna be going sideways everytime I take off. I guess I'll have to see how the 4.10s and 295/45 NT555s feel. No track time, just romping around town and to car shows.The 295s I had were great with the 3.55s lol. Once the 4.10s it was game over.
Not necessarily true. Slicks have a ton more grip but there comes a point when torque will overcome that. My drivetrain is rated at a much higher power level than I am producing, my slicks will spin way before anything breaks. Part of that is suspension set up, but throttle control is what keeps my tires planted. I can guarantee that if you hit lock up with my convertor at WOT you will spin the tires. I have to ease into the throttle to get off the line clean. When I say ease into it, I'm talking about a couple tenths of a second, maybe. But if you just mash it to the floor it will come out sideways. Even when she shifts into second there are times that I have had to pedal it to get the tires to grab again. My point being is that for any given tire, there comes a point where the driver has to maintain the traction.I agree on the driver part, but if you have proper traction, then with legit slicks on a good track, you should pretty much dead hook. That will do one of a few things........... Launch you out of the hole like a rocket, roast the clutch, break the input shaft, axles or even a stock DS or u-joints. Street tires and DR will have some spin at times, especially with high hp but slicks should hook like fly paper.
its still all comes down to setup. tires are just one piece of a complicated system.I agree on the driver part, but if you have proper traction, then with legit slicks on a good track, you should pretty much dead hook. That will do one of a few things........... Launch you out of the hole like a rocket, roast the clutch, break the input shaft, axles or even a stock DS or u-joints. Street tires and DR will have some spin at times, especially with high hp but slicks should hook like fly paper.
Interesting you bring this up. Plenty thought I'd have ABS issues too (and I'd expect them). That's why I'm looking to update my tuner to adjust for the tire size. With my setup now, the stock tires are 27.18" up front and 28.45" out back, but I haven't noticed any ABS issues. I've had her on the highway a few times too.i have an ABS question. with my setup now, i have ~27.7" in the rear and ~27.3 in the front, so just slightly off. will this cause my ABS to kick on earlier thinking that the front is spinning slower than the rear? i ask because today just once it felt like the ABS was kicking on when i was just slowing down, not hard braking at all.
