I've looked into going with a new reciprocating assembly a few times. My thoughts were that the biggest advantage of it would be the forged crank, rods, pistons giving you a good solid base to build on. If you don't want to force feed it you can go with a lot of squeeze in the chamber by choosing the right piston. The longer stroke and larger hole will help facilitate this without hanging such a large chunk of aluminum out the cylinder. Mmr was one of the shops I was considering to buy parts from. There are others. It's actually cheaper to let them build it. But that just goes against my grain. And I've heard mixed results about the delivered product from some of these shops. Research carefully
