SVTPerformance - Powered by vBulletin
The Coyote team says the forged. powdered-metal connecting rod is the least robust link in the 5.0 chain. Engineers noted it is absolutely strong enough for its naturally aspirated application in the Mustang, but just absolutely strong enough. It's worth noting that while the Coyote rod shares its big- and small-end diameters plus its center-to-center length with the 4.6 rod, the Coyote rod has been redesigned to more evenly distribute bearing loads and is definitely an improved piece.
Most ominously, supercharging will require a stronger forged rod, so we expect to see those, and, no doubt, a short-block in the FRPP catalog before long. This adds a whole new layer of commitment to bolting a blower on a Coyote. We'll have to let the brave among us prove the standard Coyote rods' boost tolerance. For those planning on a rod-exchanging teardown right away, Ford says the Cobra's Manley forged rod will just fit, but you must be careful. No word on how to package a forged piston and rod combination.
Coyotes use the same type... read full captionCoyotes use the same type of multi-plate silent-link chains as other modulars. However, with their high rpm, and unique, high torsional loads in the camshafts, work was required to tune the resonant frequencies out of the chain and guide system.Because a fully populated Coyote crankcase is packaged tightly as coach airline seating-the already abbreviated piston skirts come close to the crankshaft counterweights-there is no room left for stroke increases.
You may also think "weak" when viewing the Coyote's racy-looking but hypereutectic pistons. But there's a twist: oil-cooling jets. A fine mist of oil is squirted continuously from jets in the block's main webs. This oil sprays directly on the underside of the piston, at the vulnerable piston boss and bottom of the crown. The engineers sold the expense of oil jets to management by telling them it speeds engine warm-up (which is true), but the real reason was for piston cooling, hence longevity. This means the lighter, quieter, tighter-fitting, less-expensive hypereutectic piston can be run in this demanding high-rpm, high-load
