$5 pedal mod
1.9K views 30 replies 12 participants last post by  Safi
#1 ·
Whats this 5$ pedal mod I keep hearing everyone talk about.
#9 ·
you'll feel it yeah...for about a month until your used to it...then you won't notice it so much...but the slack will be gone at least...really helped get my R/T down at the track believe it or not..i didn't have to think about having lag in the pedal when i floor it
#15 ·
There is no lag time between hitting the pedal and moving the throttle blade.... The ONLY thing that the "pedal mod" does is raise the gas pedal.
#17 ·
In the experience with my car I tested it with and without the mod. I experienced no difference between how much the throttle blade moved when the pedal was moved 3/4".
#18 ·
In the experience with my car I tested it with and without the mod. I experienced no difference between how much the throttle blade moved when the pedal was moved 1/2".
next time use a full 1" spacer...i can see where you wouldn't notice anything since you didn't remove all of the slack
#19 ·
No, not a 1/2" spacer. I meant I moved the throttle 3/4"...I edited 3/4 in right after the initial post, you are fast.
Like push pedal 3/4", measure throttle blade movement. Then do the mod. With the mod in do the same test... I got the same results both times.
