Another one of these threads, havent seen any recently on this forum since I've registered. Theres just such a variance between setups, and I'm currently building one now, so just looking to put a good thread out there for people to check out. I've googled looking for threads like this and found a couple, but no major ones from modded mustangs!
Anyhow, post up your setup, boltons, ect (everything) and what your pulling at the track and at the dyno! I seen a guy on youtube, with a gt40p setup with a custom cam turning 320ish rwhp!!! That woudl be amazing.
Its looking like avg gt40 setups are 250ish, and gt40p setups are 260-280ish. Where are you?
Maybe this thread is a success, so I'll go ahead and post my setup, and get back with you guys when I get to the dyno and track.Maybe I can also get some more guestimates on rwhp. I've already had one guess in my other thread (Help me build gt40p setup with turbo) which I ended up not turboing yet, will go supercharger, but thats tax time.
Any more guesses?
1987 5.0 LX notch,
Stock bottom end: just freshened up, home balanced, rings, rod, main, and cam bearings, cylinders honed pistons cleaned and re torqued ect.
Tranny: AOD, Unknown, bought a parts car and had this tranny in it, looked like brand new so figured I'll give it a shot, had a trickflow trans pan on the bottom and was hooked up to a transcooler, also had a ford blue torque converter in it, the motor it came off of was hopped up, so im guessing it probably has a stall, and possibly shift kit.
Topend:
Home ported GT40p heads w/ tfs spring kit, GT40 Tubular intake (with lower and spacer), TFS stage 1 cam, bbk 70mm throttle body, 73mm C&L Mass air converted, tb spacer
Misc:
power pullies, electric fan, smog pump bypass, hooker shorty unequal headers, stock injectors, Hpipe w/ flowmasters, and K&N drop in w/ silencer delete. I also have a set of 3.73s that I havent installed, but may not due to boosting, but I know it doesnt add hp
Is 250rwhp about right with that setup?
Any more guesses?
1987 5.0 LX notch,
Topend:
Misc:
