i was researching this. I believe i should have one, or two. Where would i hook it up without issues being that im boosted? i was thinking i should use UPR's can because its not vented to atmosphere. i dont want oil sprayed on my engine bay.
One is fine.
The plumbing is rather simple as well. You just run the two PCV lines on your valve covers to the catch can.If it's a good vented catch can it should have a filter to keep all the oil mist off your engine. If you don't want to take the change, use one of the non-vented ones, and route the return/outlet back to the intake elbow.
If you've got anything running from the PCV ports you're allowing the excess pressure to be relieved.
To drop it further you need to apply vacuum, which means plumb it to the low pressure side of the intake.
Well if the catch can is in between the PCV and intake it's not much of a catch can, it's a coalescing oil filter.But you're right, a coalescing oil filter is more desirable than a catch can.
It may just be semantics. A "catch can" is a can that basically allows the oil to be dumped in from the PCV, but with a filter at the top to allow gases to escape to atmosphere.
A coalescing oil filter (oil separator) takes the PCV gases, seperates the oil out of the gas, and allows the gas to go back into the intake. It's the same as the stock PCV system, but with the oil separator stuck in between the valve covers and intake.
Well if the catch can is in between the PCV and intake it's not much of a catch can, it's a coalescing oil filter.I would advise to not run both sides of the pcv into the catch can
The catch can should run between the pcv valve and the intake.
You may be a little dissapointed in the UPR catch cans ability to stop oil vapors. The single plate design is not capable of stopping blow by or vapors
