Code P1151
1 reading
8.2K views 7 replies 4 participants last post by  v6kid
#1 ·
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank 2
I threw this code today.
Could this be caused by a vaccum leak? or an exhaust leak?
#3 ·
The fact that it's only one side usually says something. Vacuum leaks and MAF problems usually affect both sides.
My best guess would be an exhaust leak on that side or a bad O2 sensor. You could try swapping sensors side to side and see if the code changes to the other side.
