I've had the coil overs installed for a while but the car has been on Jack stands for even longer. Finally got the engine in and new tires on and figured I'd adjust the ride height. In order to get the front level there is about an inch difference between the left and right sides.
Right now the driver side is adjusted as far down as it will go and the passenger side is about an inch from the bottom. This is giving me 26.5 inches from the ground to the fender lip.
Would I be correct in assuming that there shouldn't be that much of a difference between the position of the two collars? Could it be a matter of the springs needing to settle or something?
